Old 06-11-2022, 02:28 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Default No spark 782
I have a 1981 782. Has original series I engine. Use it regularly. It lost spark a week ago. Cleaned the points. No change. Getting power to the coil and points. Installed new coil, points and condenser. Checked contacts at ignition switch. Cleaned the engine ground. Not sure what is going on, thanks for any help.
-Rick
IH 782
IH 126
CCC 1863
Old 06-12-2022, 07:52 PM
crazykilik crazykilik is offline
I’m guessing you’ve replaced the plug?
Old 06-12-2022, 08:28 PM
I am assuming, it is an IH built machine. With that in mind, considering everything is stock, wired correctly and properly functioning, you could have a bad "seat switch".
Old 06-12-2022, 10:58 PM
johncub7172's Avatar
I currently have a customers all original model 1711 that has been setting not running for 4 years. Same problem occurred, no spark. All involved components were good. The points were cleaned and engine timing set at .020 . Starting the tractor and letting off the start position, I then was getting spark too late. I adjusted the points again and tractor starts correctly now.
Old 06-12-2022, 11:50 PM
RustyShackleford's Avatar
RustyShackleford RustyShackleford is offline
Static timing helps save some fiddlin for sure.
Old 06-13-2022, 08:21 PM
Rmowl's Avatar
It was the timing. Went through the same procedure, got spark, fine tuned it and now runs smoother than I’ve ever heard it. Thanks for all the help everyone!
-Rick
IH 782
IH 126
CCC 1863
