Old 06-11-2022, 11:10 PM
1004ron 1004ron is offline
Default My new CC30H leaves strips uncut
I haven't had my CC30H long, only have about 6 hours on it.
What's bugging me is the strip of uncut grass it leaves, even with me maintaining a significant overlap.
Today before I got underway I confirmed the tires were 10 psi on the rear, and 14 psi on the front.
I also went slower and it seemed a little better.
Is this just something that's to be expected with this mower, or is there something I can do to improve things.
Is there a better third part blade?
Old 06-12-2022, 06:20 AM
Where did you purchase it at? Did you check the blade? Got any pics of the underside of the deck you can post?
Old 06-12-2022, 07:30 AM
Is the blade mounted correctly and is "sharp"?
Old 06-12-2022, 11:10 AM
Farmall450's Avatar
I would hope both of those are true, since the blades come on them from the factory. So unless the OP had a different blade put on, interesting.
How tall/thick of grass are you mowing, is it at WOT, and are you mulching or using the side discharge?
Old 06-12-2022, 11:36 AM
Billy-O's Avatar
Billy-O Billy-O is online now
Agree with the others, blade is my 1st thought. Also.... Is the belts (if any) and PTO functioning properly.
Plow blade
#2 Cart
QA36 snowthower
Old 06-12-2022, 11:40 AM
One or more blades on UPSIDE DOWN!!
For Pete's sake, pull the deck and flip it and take a look.
Issue should be readily apparent I would think!
Old 06-12-2022, 06:34 PM
The grass is fertilized and seeing good rains and loads of sunshine - I cut once a week with the mower set at #3 - the grass is about 5" at the time I cut.
Yes, WOT.
I'm using the mulching cover.
Can't get a good photo.
Old 06-12-2022, 07:04 PM
Farmall450's Avatar
Yes, WOT.
Cutting higher/more frequently might help. Plus it's a lot better for the grass to not knock off more than 1/3 of it at a time.
