Looking for threads to build a category 0 3 point hitch for 3186.
Walter |
I don’t think anybody has built one yet. There are 2 different versions for the 3k machines. The 207 & 365 depending if your machine has the CI rear or not.
I'm pretty sure mine is the 207 from the diagrams I have seen.
Walter |
I just need a good used rock shaft. Not a new one.
Walter |
Walter,
Post a good clear picture of what you do have so far. Lay it out on a nice surface free of clutter so we can see just what you have.' Also include a good clear picture of the rear of the Cub, mainly the rear plate between the wheels. The rock shaft is a welded assembly |
Just build one and make it better use real bearing blocks on the back plate. You can cut the back plate for the hydraulic cylinder or mount everything outside the back plate and possibly use two cylinders. The amount of movement of the stock 3 point is minimal and you can do a lot better with your own build.
Bill |
All I am missing for a 190-365-100 Hydraulic hoses and cylinder. The cylinder I can get from a supplier. finsruskw made me a new rear hitch Plate and some rocker-shaft Mounting brackets. The 190-365-100 Only works with aluminum transmission case tractors with external Brake controls This boneyard https://www.ihccw.com/ might still have a rocker shaft for a 190-207-100. I am finally purchasing a 3208 to mount the 190-207-100. I'll just have 3 leavers, though I won't have the 4 leavers. But thanks to this https://summit-hydraulics.com/produc...button-switch/ I'll have 4 outlets and will only need one lever. I'm also getting a 54-inch Blade with the manual angle kit, so the next search will be for the angle kit and horses for that to use in the Summit multiplier
0riginal, 60 RER, 70, 106, 1450, 1541, 2182, 3208, XT3GSX & SX54 Z Force |
If you could send me some pictures and measurements that would help a bunch.
Walter |
Checked his site and did not see any shafts.
Walter |
Send Him a question I notice some times he doesn't always put everything out there for sale
