Old 04-16-2024, 06:09 PM
Terrh Terrh is offline
Default 1864 no/weak reverse
I've got a 1990's 1864 I bought last year in an effort to not have to fix my awful modern home depot-style mower every other time I mow my lawn.
It's got fairly low hours and is in nice shape, but I noticed that when I bought it that reverse was kinda slow. Still, it worked, and I don't have to reverse that often.
Lately reverse almost doesn't work at all, though. The fluid is fresh and to the fill line in the hydrostat unit. Maybe even a touch high, but not much.
It also seems to speed up on it's own going forwards sometimes.
I tried adjusting the linkage under the cover in the middle of the mower, but it didn't seem to improve anything and I think it's adjusted properly.
I'm maybe imagining things too, but I swear the pump has gotten louder recently. Almost sounds like it's got low fluid, but, well, it doesn't.
Any idea what to try next?
Old 04-16-2024, 07:29 PM
When is the last time you changed the filter?
Download the service manual for the 82 series, the transmission linkage adjustment is the same. https://www.onlycubcadets.net/forum/...ad.php?t=13226
Old 04-17-2024, 12:55 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Change the filter for sure.. and check the trunion springs, spacers and the trunion slot.. very prone to wear.. I also remember seeing a service bulletin years ago on the early Cyclops tractors for slow reverse.. not real sure where to find it now though
Jay
Proud owner of the following:
Old 04-17-2024, 05:16 AM
Here ya go.
Slow reverse.pdf
Old 04-17-2024, 08:40 AM
Check to see if the Go Go handle is still attached properly to the cross shaft under the dash.BTDT
Up to 534 and counting...
Old 04-17-2024, 11:23 PM
jaynjeep's Avatar
Here ya go.
Attachment 114839
Thanks Todd! I knew I had seen it somewhere before!
Jay
Old 04-18-2024, 06:47 AM
goonpeden goonpeden is offline
One thing I would try is switching the pressure releif valves around. If reverse is good and forward not then you got a bad valve, if that is the case contact Mac Tech for valve rebuild. I have had several sets rebuilt by him and work is Excellent! Bill
Old 04-24-2024, 08:24 PM
danman danman is offline
Anybody recommend a source for these trunion pieces for a 2182?
Old 06-24-2024, 11:36 AM
Rex B Rex B is offline
Default Related question
My 2084 has the same issue, almost will not reverse.
I have a 2063 I bought for parts. It has a good hydro, but I underrstand it's a different make than the ones in my 1864 and 2084. Any chance the valves are the same?
Old 04-18-2024, 02:30 PM
CubDieselFan's Avatar
This should help with the no reverse issue.
https://www.onlycubcadets.net/forum/...ad.php?t=27165
