Old 05-18-2024, 05:51 PM
Possum Possum is offline
Default 1440 carb removal...how?
Have a new carb to replace the old gummed up one... it looks like it unbolts from the BOTTOM.... am I seeing this correct? If so, can anybody direct me to the removal/reinstall procedure.
Old 05-18-2024, 06:07 PM
Remove the air cleaner, base, hose, linkages, fuel solenoid wiring, and you have to remove the 2 nuts at the bottom of the carburetor.
Remember what holes you remove the linkages from.
Up to 530 and counting...
Old 05-18-2024, 06:20 PM
ironman's Avatar
ironman ironman is offline
Take pictures.
Old 05-18-2024, 06:32 PM
Vanguard carbs are easy to clean. Have tried cleaning the one on the machine? Just remove the four screws on the top and you can clean most of it. You might need to remove the shutoff solenoid also. Is your new carb a new el cheapo from Scamazon?
Old 05-18-2024, 06:16 PM
ironman's Avatar
Does this help?
