Have a Cub Cadet 1210 that hasn't run in 5 years which I have to move out of my shed before it can be picked up. Couldn't get it to start then ("varnished," fuel lines?) so no way I can get it to start now. Haven't been able to move it in neutral. Is there an golf cart type of "tow" switch on the 1210? Thank you in advance!
No there is not. You can push it or tow it but you can only go baby steps.
Hi darkminion,
Thank you for your prompt reply! Bummer that there is no way to roll it, but just a 1st world problem!
With a helper, you might be able to move it by putting a small hand truck under the transmission between the rear wheels. Block it up if needed...and push hard!
In order to move my 782 around I put one of these under each rear wheel.
https://www.harborfreight.com/18-in-...lly-58312.html
2005 CC GT2544 1980 IH CC 782 1957 Cub Lo-Boy 1993 Craftsman LT4000 |
The 1210 has auto relief valves on the hydro so you can push it or pull it at a slow walking pace for short distances.
