Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 02-26-2025, 05:01 PM
Cubcadet782desiel Cubcadet782desiel is offline
Default battery recommendations?
My 782d used to have a top post battery should I convert it to a side post to get a bigger battery and I am not doing the GR starter.
Old 02-26-2025, 05:51 PM
CubDieselFan's Avatar
What battery does it now? What is the cold cranking amps rating?
My 1572 has a 350 CCA top post battery. It is 6 years old and it has top posts.
Old 02-26-2025, 06:58 PM
it has 250 I was just wondering because I could fit a bigger one in, but it has died on me twice in the year I had it it would spin over once and themn stop most of the fall it started right up. and is it a common problem for the exhaust manifold bolts to snap off. and how do I get them out, what grade bolt should I use. what is the torque spec for the exhaust manifold? Thanks,
Old 02-26-2025, 07:01 PM
I don't remember the brand
Old 02-26-2025, 07:14 PM
The glow plug upgrade would help you a lot. Get the biggest CCA battery that you can find, that will fit.
I have never had the bolt snap on my 1572 because it has a bracket that is connected to the engine for support. I had all but 2 break off on a 1782 because it does not have the support bracket. We had to weld a nut to the bolt and then unscrew it from the head. Below is a kit with the factory parts that i have listed on ebay. These are what I used. I am not sure on the torque specs but they are probably in the manual in the tech section. Post a picture of yours under the hood.
https://www.ebay.com/itm/264790008443
Old 02-26-2025, 08:04 PM
Thumbs up
i will get the picture this weekend or next weekend
