Old 04-29-2025, 09:42 AM
rwatts65233 rwatts65233 is offline
Default zt2 60
Im new from missouri, have a 2019 year zt2 that the clutch wont engage, the problem is in the ground circuit, which i assume goes through the seat switch and lever switch to create a ground, i had tested switches and installed test switches i had on had, nothing seems bad, if you run a seperate ground wire to the clutch it engages fine, i as suspecting a relay thats in the harness by the pto and key switch but i dont see it available in any parts break down, i dont have a wiring schematic to go by, any help would be appreciated, thanks roy
