Got my creeper gear installed on my 126 and it doesn't see to be reducing my speed. When I installed the creeper I had the entire rear end off the machine and when I spun it the hubs spun at a reduced speed as it should have. Now that it's on the machine it doesn't seem to do that. I don't believe anything has broken(didn't hear any abnormal noises that would make me think something broke)
Any suggestions? |
Does the selector have full range of motion?
I installed an aluminum creeper gear on my 128 once and all I had was high speed and neutral.
128 X 2, 129, 149, 1250, 1450 x 2 |
It does, I can pull it the whole way back and push it forward the whole way, it seems to be the same speed
Was it or has it been rebuilt?
To my knowledge it’s all OEM
Wondering if you just bought it and installed it or did you
go through the internals? Making sure there was nothing suspicious on the inside. How exactly are you shifting from high to low? Are you at a stop with RPM's at idle? I'm curious. If you put it in high it drives in high, correct? If you stop the tractor and turn it off, shift to low, does it then move in high gear? Ken |
