Hello Everyone I hope you all are doing well.
Yesterday while changing oil in the K301 I found this laying on top the oil drain pan. I was hoping one of you Kohler gurus would recognize it. The engine is running fine & I just mowed 5 acres with it after the oil change. The old oil was 10w30 & it was black, it now has straight Heavy Duty 30 weight in it. I put my finger in one of the pics to reference the size of what looks like a piece of cast gear tooth. Thanks for your input. |
Gazing into my Chrystal ball. I see a dentist in your future to replace the missing tooth with a full set of teeth on that gear.
I also suggest you purchase a lottery ticket because your luck of averting a disaster was great. I also see internal engine surgery in the near future.
In the meantime it has work to do & will hopefully get through this season. IDK if that's a tooth off a cam gear or balance gear or even when it came off. I suppose I should stick a telescoping magnet in the oil drain pan to see if any more teeth are in there. |
You’ve been lucky up till now, but myself, I’d quit running the engine and pull it apart before some of the internals try to become externals. Right now it may be a simple matter of removing the balance gears.
Could it be a tooth from the governor gear? Measured exactly how long it is. Edit: It looks like only part of the tooth lengthwise? Definitely get a magnet in there. Better yet, get the pan off. |
Yea good idea.
As small as it is, I'd guess gov gear.
No balance gears in a small kohler. You can try snaking a borescope in the drain plug opening, if more break off, you will have a big window in the block to look into.
Fix it NOW!
Before it's too late. |
My wife says I do not listen , at least I think thats what she said |
This appears to be a very small piece of a tooth off a tiny gear. I will look in the oil drain pan & see what I can find in there with a magnet the oil is black. |
The monkeys with hammers showed up & they don't play a good tune.
