The 10 hp Kohler gave up the ghost and I tore it down...the crank journal is chewed up and the bore is scarred a little. The old piston was .030.....if I remember , that is all she wrote for boring the cylinder...think this one has fought it's last fight.
Any advice would be appreciated.... Rick |
If the bore is just slightly scratched most times it can be reused.
Was it using oil/burning before you tore it down? a reputable machine shop can sleeve it back to std. size. does the crank measure standard size or is it undersize? if standard it can be turned undersize and fitted with a new rod. What you might want to do, is see what that machining/parts would cost vs. a good used engine. I do remember it being mentioned that a larger piston from a 12 h.p. can be fitted but can't remember if it was a Kohler or not, I'm sure someone will post here. |
If the PTO end of the block has 'K301' cast into it, you should be able to go to a 12 hp standard piston.
I've been saying that the local IH dealer and my father in law both claimed that they upped his first Cubs C.I.s by boring to the next size.I've been saying he went from 7 to 10 hp, Now you have me wondering if his first Cub was a 10 and bored to 12!Only thing I'm sure of is it was a 64 or 65 Hydo unit and that 10 HP was involved not even sure of the model just that he bought it new late 64 or very early 65 |
That's possible. I think a lot of the early 10 hp engines had the "K301" cast into the block.
Thanks to everyone....
Matt...looked for the stamp....any idea where on the PTO side is would be....so far I'm unable to find it. |
