My pastor gave these to me today. As soon as I get time I will attempt to convert these over to sleeve hitch type implements. The plow will require the most work - some one already tried to convert it over, but it needs to be reworked.
If any one has dimensions on the plows, let me know - I need measurements from the plow to the hitch, height, etc. And maybe some ideas on how to make the plow adjustable. |
Nice attachments, Terry! Good luck on converting them.
Woohoo Tmo. You got some cool stuff there, that plow looks to be and 8" or 10" and should work good for you. A disc and cultivator, now you can farm till you fall over.
I wonder what make they are? No matter, you can make em' your own and use the crap out of them. Way to Go; Cadet Farmer |
Tmo. I just took another look, if you want to adjust your plow you just need to be able to tip the point up or down to make it go in the ground.
If you need any help just give a holler, if you could get them over to Rolla, I am always welding and fabricating, be glad to help out. Cadet Farmer |
CF,
I might take you up on that offer. I haven't been to Rolla in years, it's about time I make that trip again. |
Ya know Tmo. We need to know what size that plow is, 8, 10, 12inch. Cause I've got a couple 8" plows already set up for sleeve hitch, we could just swap and save us some work, since I don't use a sleeve hitch anyways.
Cadet Farmer
that digger thing looks like one my buddy has on a sears tractor
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
I wouldn't be too hasty cutting that rear grader blade up. They all appear to be for a Sears, (Roper), tractor, (60s and 70s). I have a 1971 Sears Surburban SS-12. That rear blade will bring a pretty penny, they are rare. I ended up buying a Craftsman sleeve hitch rear grader blade and adapted a sleeve hitch frame to my 3 point hitch to be able to use it because I couldn't find the Sears 3 point rear grader blade. Just my 2 cents.
Sounds like a plan to me. I don't think this ground here can handle anything larger than a 10 inch plow, so 8 inch should be fine.
