Didn't know quite where to post this, but this VR looks like the type used on older IH Cubs. What is the jumper type non-metallic, wire-wrapped rod that connects across two terminals on the bottom?
Perhaps a fuseable link? It is somewhat easily removed by opening the clamp ends. I did some damage to the wire, and had to re-wrap with new wire that is just a hair thicker. I'd just like to know what this piece does, and if my repair will suffice. Thank you. |
It is a "wire wound resistor".
Okay, thanks. Being a resistor, I wonder just how crucial the wire thickness, type and number of winds will end up being. I can't simply fire it up and test it right now, since the tractor is being built back in a restoration effort. I'm just now putting the electrical back in, and probably a few days away from test-firing the motor.
I appreciate the input. |
Wire wound resistor are more precise than carbon core. I don't know the original value of that resistor, but I would say it would precisely designed.
I see.
Well it's either plunk down $50ish and replace it, or try to repair it and expand my wee brain a bit. So, I've put on a thicker wire, with a guesstimated number of wraps. I've likely lowered the resistance at this point. I'll have to wait til I get home to see just what I my be sending more juice to. Thank you Sir. |
This is a Wiring Diagram of a Typical Circuit.
As you can see, there is a Resistor (in blue) to ground within the V/R. That is what your issue is about.
Are there not any markings on there that tell you the specs of it? I always remember looking at a chart for color codes on ones I used on my "learn to solder" kits that i had as a kid. If there are any markings on it you might be able to use it to just replace the resistor itself.
