Old 01-21-2011, 08:45 PM
Default Finally pulled the K321 out of the 1450
Been awhile since I have posted. Now that hunting season is over, I have picked up the wrenches and what I have found ain't good. I pulled the engine. 1st problem, PO ran without checking mount bolts on oilpan for a long time. I will replace with a cast iron unit. I noticed excessive movement at the rod to crankpin. Pull piston and mic'd crank journal. 1.490, 1.489, 1.490 then 90 degrees 1.495, 1.494, 1.494.
What to do with the crank??
Option one, turn .010 and cross fingers.
Option two, turn .020 and use aftermarket rod.
What is the best rod to use??
Option three, turn .020 and use bearing inserts on a new modified Kohler rod. What bearing inserts do I use??
Option four, find a better crank.
Anybody have one lay'in around?
I also found the cam endplay to be .028. Can I just shim it to spec or is the cam wasted??
The rest of it looked surprisingly good. And NO balance gears.:biggrin2.gif:
Price is a concern but not time. I have my 1200 for mowing duties and can drag my Fergie to the house to disc my garden spot this season. My plan for the 1450 is to pull my Brinley plow.
Need some wisdom here. Thanks a bunch.
Old 01-21-2011, 09:30 PM
Roanoker494 Roanoker494 is offline
Glad to see someone bringing a "old one" back from the brink, I am in the middle of a engine rebuilt myself. The only advise I will give is that it is always a bad idea when fingering crossing is involved.
Johnnie Watkins
All original Model 800, what else could I want?
"Thought I was wrong about something along about three years ago, but as it turns out I was only slightly mistaken."
Old 01-22-2011, 08:58 AM
Dave R Dave R is offline
Default K321 rebuild
I have a K321 thats going to come out just as soon as its warm up a bit. My shop outside is not heated, so the weather has to be better.
I called O'Reilly Auto Parts (This is not a commercial) and asked if they had a machine shop. They do, I can take the block and crank to the local store, they will pick it up, machine the cylinder for $40 and machine the crank for $35. and return them to the store. The lad said it would take about a week up and back now. I put this on here only because most of us have an Oreilly store close by.
I am anxious to get mine done.
Dave in SW Missouri
Old 01-22-2011, 09:16 AM
Mike1450's Avatar
Mike1450 Mike1450 is offline
Battlewagon:
My K321 out of my 1450 had similar issues on the crank. The machine shop cleaned it up nicely only going .010 under. Its typical on these engine that the crank pin gets a little out of round. Even if you had to go .020 under you should be still good.
I would use a Kohler rod over an aftermarket version.
The cam should have shims on the end already. My cam end play was out a little as well. I found that the shims in there were worn down. I replaced them and it was back in spec.
Old 01-22-2011, 09:24 PM
Originally Posted by Mike1450 View Post
Battlewagon:
If I go .020, I have not found a Kohler rod. Is there a part number I am not aware of?? All I found for Kohler is std and .010.
Old 01-22-2011, 09:30 PM
Merk Merk is offline
by Battlewagon
You have to take a Kohler rod to a local machine shop and have them modifiy it for bearing inserts. The local machine shop should have access to part number for bearing insert.
Old 01-23-2011, 12:52 PM
Local machine shops near here, either cater to industrial type work or automotive and claim they do not work on small engines. If someone here knows what bearing inserts will work, I could get them and have the industrial shop fit them to a Kohler rod. No matter what I do the crank will have to be sent somewhere. Any machine shops that are better than others who don't mind shipping??
