My 109 won't run right, I've been doing a lot of plowing snow, and all the sudden tonight, it wont run right. I adjusted the carb, cleaned the plug, and checked the point gap, still not fixed. Anyone thinking water in the gas? I'm just going pull the carb and clean it, because its still snowing here. any other ideas?
Please elaborate on 'won't run right'...that could mean a hundred different things. Won't stay running? Runs rough? etc. We could list a bunch of stuff for you to check, but help us narrow it down a bit.
It idles, but when you pickup rpms, it bogs& almost dies. Dirty main jet?
sounds like it's in the carb, probably main jet
Cub Cadet 149 IH Lawnboy 3321 IH Cub Cadet 782 w/ dual hydraulics-M18 powered 1977 Wheel Horse C-160 8spd w/ 48" deck, dumpcart |
OK I've cleaned the carb, put water remover in the gas, cleaned the plug, set the points, and it still wont run right. Ive adjusted the carb to the specs and adjusted both ways from there when it is warm. Should i get a new spark plug? I'm thinking it's somewhere in the ignition system. coil, condenser, i don't know. I'll look at it after church.
If it starts right up, no problem, I don't think you have ignition problems.
Is the governor working?? I would check that 1st. Next I would check the fuel flow. Perhaps partially pluuged line, or tank outlet, not providing enough fuel. I assume it isn't blowing black smoke??
Roger,,109,1450,1210 ![]() Some Days all You Can Do Is Hang On!!! |
