Old 03-25-2011, 07:00 PM
B-Brush B-Brush is offline
Default cub original steering part
im trying to restore the O today i removed the steering wheel had a lot of slop in it on the top of the steering tube there is a cap and the bushing fits into this can someone tell me what this part is called or where i can get one i have looked at the sponsor sites and did not see anything
Thanks ,Bob
Old 03-25-2011, 07:15 PM
Sminkey
Guest
Posts: n/a
Here's a link to the upper bushing for the the steering column. http://ihccw.com/steering.html Near the bottom of the page you'll see part #IH 866105 R1. That's what you're looking for
Old 03-25-2011, 07:51 PM
juniors1282's Avatar
Bob, If you want to get ride of the slop at the top of the column you might want to up grade that bushing to a bearing. You can pick up a bearing at your local farm store. Take that sleeve at the top of you column off, just tap it off with a punch and hammer. Then you can install the bearing in the column and put the cap back on. I buy the bearings from TSC for like 5 bucks, you have to take a little bit off the edge of the bearing to get the cap back on but not much. I just did one this week. I used a Hillman radial bearing size 3/4"x1-3/8". Once you put the steering wheel back on you never know it's in there and your column won't move around anymore. I tried to take a picture but it just wouldn't show it very well at all. Good luck.
1966 IH cub cadet 102x2
Old 03-25-2011, 08:01 PM
This is the bearing he is referring too. Got mine at TSC also.
Old 03-25-2011, 08:05 PM
Yep there you go I couldn't get my picture to turn out with the flash and to dark with out. Thanks DX3
Old 03-25-2011, 08:09 PM
Welcome, I just happened to remember I had that one. If it fits a bit loose, like mine did, I used a bit of black Silicon around the shoulder to secure it to the tube. I can't get over how smooth the steering turned out with that added and the SGT upgrade thrust bearing and ny-lock nut.
