Old 11-22-2011, 09:57 AM
greasemonkey greasemonkey is offline
Default Cat 0 for 122 or Narrow Frame?
Does any one know for 100% if there is a Cat 0 hitch made for a 122 or narrow frame tractor and it will definately fit?
Old 11-22-2011, 10:03 AM
All of the NF lifts will fit your 122. It's not a true cat0 hitch. Check this out from the tech section of the site.
http://www.onlycubcadets.net/forum/showthread.php?t=4
Old 11-22-2011, 10:22 AM
IHinIN IHinIN is offline
Xtreme Motorworks make a Cat 0 for the narrow frames but I'm not sure which models it will fit.
Old 11-22-2011, 12:24 PM
From their web site:
Will not work on tractors with PTO. Designed to be similar to the 82 series kits below. Will fit the following tractors without PTO:
107, 127, 147
May fit other narrow frames with some small modifications to the lift shaft.
May fit others, but not tested yet.
http://www.xtrememotorworks.com/Part...rts%20List.htm
Old 11-22-2011, 12:42 PM
Yeah I seen that one from xtreme, but $500 is a lot to be a test dummy........
Could some one give me some dimensions? Width across from bottom lift arms, and the height from bottom lift pins to top link?
Old 11-22-2011, 01:56 PM
these are the dimensions im looking for. i need to get a hitch for my tractor and since im going to spend $125 to $150 for a sleeve hitch setup i figured i would make or buy a cat 0 3 point set up and be able to use both ways......
if i can get dimensions ill buy the lower lift arms and make the rest, should be pretty straight forward. im hoping to tuck a small cylinder under the tractor to use for lift and down pressure......
Old 11-22-2011, 05:05 PM
You'd be better off getting the IH-style 3-point and sleeve hitch adapter and using sleeve hitch implements. They are cheaper and more properly sized for a 122's size and horsepower.
