Hello all, and thanks in advance for any help you can provide.
I've had a 125 for a little over a year now, and it's run like a champ. This month I got permission from the wifey to look for a different mower so I can start restoring my 125. I think it made the 125 jealous. The Hydro fan shroud came loose and rattling around if I try starting it up (I only tried starting it once, heard the rattle then found out that the shroud was loose). Any advice on how to go about re-securing it? Can I do this from underneath or do I have to start taking things apart from the top? Thanks in advance. ToineWI |
![]() I've never seen one in person before but I bet you could bolt it back up with a lock nut. You will have to do it from under the tractor. |
Welcome!!!
The shroud is attached by 4 screws.The heads of the screws are slotted and are located on top of the frame in front of the seat.The shroud has 4 clips one for each screw,but they may be missing.Pictures would help.
You guys nailed it. The four screw holes (visible from the top of the 125's frame) are indeed missing screws. Hoping to remove the deck and take a look underneath today. Thanks for the quick answers!
| Tags |
| 125 |
| Thread Tools | |
| Display Modes | |
