Old 08-04-2012, 10:09 AM
dlampo dlampo is offline
Default 782 Hydro Coupler
First off I would like to thank everybody here for all the great info available on this site. I saved a 782 that was headed to the scrap heap with a blown engine, and with the help of this site, I am getting close to having it running again with a replacement M18!! The original drive-line was worn very bad on this tractor and I have already had a new drive-shaft made. The hydro coupler also is worn pretty bad on one side, and the bearing in it has separated and fallen out. When you buy a new coupler is this bearing already in it or is it purchased separately? It is kinda hard to tell looking at the parts diagrams.
Thanks for you help
Old 08-05-2012, 09:22 AM
IIRC...the bearing insert is part of the coupler.
Old 08-05-2012, 11:16 PM
No, it's not part of the coupler. It may come with it, but it is available separately.
Old 08-06-2012, 06:34 AM
It kinda looks like it does to me.....
Old 08-06-2012, 08:13 AM
It comes out and is replaceable separately...something tells me you've not had one apart before...
Old 08-06-2012, 08:21 AM
You are wrong again...
The part I posted will take care of the bad coupler and bushing.
Old 08-08-2012, 12:48 AM
Hey guys thank you for your help. It looks like if I order part #903-0794 that will get me a new coupler with a bushing already installed in it. Matt on the parts diagram I see what you are talking about, you can buy the coupler and the bushing separately. Oh and WOW I just looked up the price of that coupler Cub cadet is proud of that part. One other question that bushing looks to be a sperical brass bushing held inside of a steel insert. On mine the brass bushing fell out and the drive shaft wore thru the steel insert and into the coupler. So far I have been unable to get that insert out of my old coupler. If I can get that insert out do you think it would be worthwhile to try and have the coupler repaired and install a new bushing, or just replace the entire coupling?
Old 08-08-2012, 07:35 AM
Here ya go.
http://www.onlycubcadets.net/forum/s...light=triangle
Old 08-09-2012, 08:31 AM
If the only thing wrong with the coupler is that wear spot and then new bushing fits securely, I'd re-use it. The coupler usually wears in the bore where it attaches to the input shaft- if it wobbles on the input shaft, it needs to be replaced.
Look up that coupler for a QL like a 1450...it appears to be the same thing when compared to the 82 series one, but is a different part number and was about half the price last time I needed one. I've used those each time I've had no choice but to buy a new one.
Old 08-09-2012, 11:37 AM
TheSaturnV's Avatar
Cub Cadet is equally proud of ALL their parts.
