I bought a spare engine that came off a 149. It had not been run in a while.It Had a Walbro 60 carburetor.Of course it did not run right.It would only run with the choke nearly closed,like it was starving for fuel.I disassembled it and soaked it in carb cleaner,but it did not help.So,I gave up on the Walbro.I got a Carter Kohler #30 carb from Ray (Thanks,Ray) and the engine runs and starts great now. I was just thinking,if I could somehow get that Walro carb to work,then I would have a spare.Has anyone had any luck bringing a Walbro back to life? Or am I just dreaming?
Thanks.Tim
Cub Cadet 100 "Super" (red) show tractor Cub Cadet 100 show tractor. Cub Cadet 100 worker Cub Cadet 106 refurbished/modified (red/white) Cub Cadet 128 "refurbished" Cub Cadet 1450 my dedicated mowing tractor Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper. 100 w/pan seat and 3 point hitch |
Walbro's are excellent paper weights.
Make sure the main fuel inlet needle that goes from the fuel bowl to the middle of the carb is clear. A small pin for fabric works well for clearing them
Thomas, I don't understand what you mean. When I look into the center of the part that protrudes down into the bowl, I see the end of the needle sticking out. Since this is a Walbro, I don't know if it is possible to remove that needle/jet.
IIRC, all the Kohlers for Cub Cadet, in that series, had the adjustable Kohler (Carter) Carbs on them,
I have two newer Kohler K series replacement engines in a 129 and 126 and they both have Walbro carburetors on them. I havent had too much problem with them yet....keep in mind i said YET....
never had a walbro carb on anything, but from what I've heard, it's best to avoid them like the plague.
if there is what looks like a screw on the top of the carb it is the fuel inlet needle and that is removable just get your self a rebid kit for it
I still say 'not worth it'.
The plastic floats get eaten by all the crap in today's gas, and the rebuild kit is pretty expensive for what you get (but still not quite as bad as for a Command single...). The 'adjustable' ones aren't really all that adjustable, and the non adjustable ones are always either too rich or too lean. |
The best luck I've had with the Walbro's is seeing how far I can throw them.
![]() All kidding aside, it's truly your choice to try to "rebuild" it, but IMHO, not worth trying.
Josh Diesel Cub Cadets........... |
| Thread Tools | |
| Display Modes | |
