Does anyone have any pics of a 782, with the front blade attached? If so, I'd like to see them. I got a WF subframe yesterday. I traded my NF one with Earl S., yesterday while we were visiting. Thanks in advance!
Thanks Roland! I knew it, but wanted to see some pics.
Another quick question. Will I be able to use this lift rod bracket with my 782?
No, you won't Allen.
The rod won't clear the frame. |
Thanks Mike!
Does anyone have a pic of the WF lift rod bracket? Also, can a bracket be fabricated? Thanks again!
Allen,
Look under home made for my hydraulic power angle set up. It's mounted on an 1811 which is the same tractor. The lift arm on the plow is for a wide frame. The 82 series lift bracket is even different. But a wide frame will work. The 82 series lift rod is 5/8 I think and has a bend in it to clear the side panel. I just used a 1/2 rod which I bought 2 adjustable ends. Not installed yet. |
Thanks Mike, I'll check it out!
Allen I have a front blade that goes on my 782. Ive got the rear fenders off and doing some work on the rear end now as soon as I get that done ill can snap some pics of the blade mounted. I think my lift rod has been modded a little.
Don Smith https://www.facebook.com/SouthernKentuckyCubCadetClub IH 982D aka "The Big Red Smoker" BRS w/3pt hitch CC 1572 aka "The Big Yellow Smoker" BYS w/3pt hitch-PTO Brinly Cat 0 3pt plow-Brinly sleeve hitch plow Custom Hydraulic lift disc-Haban Blade-Brinly Cultivators Cub Cadet lawn trailer and lawn sweeper |
not a 782 but the same , other then yours is hydro lift. I also had this blade on the 882.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
Thread Tools | |
Display Modes | |
