Old 06-09-2013, 07:15 PM
Rdrnek Rdrnek is offline
I currently have a 126 jigsaw puzzel I am working on. I bought it in boxes but it had a lift and a brand new replacement k301. Good luck
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
Old 06-09-2013, 08:46 PM
cubby102's Avatar
cubby102 cubby102 is offline
The main reason it was taken apart was to refresh the paint on it which still looks pretty good for not being assembled for 20 years but he's wanting to use it again finaly how he found out about me I'm not real sure he lives in normal il. I do believe had another buddy of mine go and pick it up since my ram is still a little down and out with a bad rearend so far I got the fenders and dash and a few of the electrical parts put on also I figured out the hydro linkage from a few pictures in the service manual now its on to the little stuff like safety switches and what not
Old 06-09-2013, 11:37 PM
cubby102's Avatar
Ok guys ran into a couple road blocks here. One being a stuck exhaust valve which I can take care of second being where in this world does the voltage regulator mount on this thing. I havnt been able to find much on where its mounted thanks all
Old 06-10-2013, 12:38 AM
It is supposed to mount underneath the seat in the battery compartment, on RHS of battery when you are facing the steering wheel.
Old 06-10-2013, 04:52 AM
cubby102's Avatar
Ok sounds easy enough. Any pics so can see exactly what I'm looking for I only remember seeing one hole back there shouldn't there be two? Or is there a bracket
Old 06-11-2013, 12:20 AM
cubby102's Avatar
Ok I have found out where the vr mounts and I cleaned the carb tonight. It fired right up so now I need to get all of my testing wires off and install the harness. Need to get a new dowel pin for the engine side of the driveshaft. As it was apparently cracked and tried to be a bullet flying by my head.
Old 06-11-2013, 12:29 AM
Never good having shrapnel flying past your head
Good to hear it runs
Old 06-11-2013, 02:22 AM
cubby102's Avatar
Does anybody know the size of the metal dowel pin in the driveshaft? I needa get that pickex up tomorrow as my goal tonight is to get it running so I can move it around so I can get to work on the deck
Old 06-12-2013, 11:37 AM
cubby102's Avatar
Well guys its alive. Need to put a float kit in the carb and find a new fuel tank but she runs great new points and replaced the relief valves with some good used one and this thing runs amazing. Heres a few updated pics
Old 06-12-2013, 11:39 AM
Looking good! Thanks for the pics.
