Old 02-17-2010, 08:35 AM
The 982 sits higher than the standard-frame GTs. The tiller won't go all the way down, so you'd have to come up with some way to mount it lower that isn't going to throw off the belt alignment.
Old 02-17-2010, 08:46 AM
Darrell Darrell is offline
Never thought of that or done a side by side comparison , but how does a SGT sit higher ?? Do you mean the tractor itself sits higher or the tiller gearbox/hitch sets higher ??
Old 02-17-2010, 09:08 AM
All of the tires are taller, so the SGTs have more ground clearance.
Old 02-17-2010, 09:42 AM
Mountain Heritage's Avatar
So what your saying is .... I can't put a tiller at all on my 982?? Anyone have some suggestions? If I can't put a tiller on it, I guess I am going to have to look for a cultivator or something??
Old 02-17-2010, 12:39 PM
hawgwilde's Avatar
hawgwilde hawgwilde is offline
Default 2 cents..
I'd be looking for an off brand,gas powered tiller..would be less headaches with operation..just fab up a bracket to mount to the 3 point on the tractor
"You Can Only Drive One Tractor At a Time..Why Do You Have So Many?"
Old 02-17-2010, 01:22 PM
Hmmmmm.....any suggestions on a supplier/manufacturer of a gas type tiller Hawg?
I am kinda wondering if I did find a 2B tiller I could perhaps have a longer arm for the upper and lower hitch to allow the tiller to go down further due to the taller tires? Not sure...will have to do some experimenting??
Old 02-17-2010, 03:26 PM
hawgwilde's Avatar
All the tillers I've seen are used...will keep an eye out, just in case..maybe possible to lengthen the arms...or longer pin??..my #2 tiller is in storage up north..might be a while until the snow melts to access..shoot me an email Mountain..lost all mine
Old 02-17-2010, 04:26 PM
cubby cubby is offline
i have noticed that blowers have gone up allmost 100 dollars sence the snow started flying. that said iv noticed also that hardly any ads here in wi for summer attachments.
Old 02-17-2010, 04:52 PM
Yes, I figured with the economy peoplw would be dumping things???
