I have a couple of questions I am hoping somebody out there can help me with. First the brake/clutch pedal on my 580 doesn't have enough travel to completely disengage the idler pulley. It's difficult to shift without grinding the gears. I can't see any adjustment on this, only a large spring which appears to be OK. It hasn't been over extended or broken. The pedal is only a few inches above the foot rest when the transaxle is engaged. Secondly, there is an oil leak from the right axle shaft. I have a new seal am not sure how to go about installing it. I think I should remove the right axle housing from the transaxle housing but am reluctant to do this in the event several parts/pieces come tumbling out and leave me wondering where they go. I need a diagram or some expert assistance. Thanks for the help.
Denny Original Member # 389 Saw It Wanted It Had A Fit Got It ![]() ![]() ![]() MY Cubs Original x 2 , 70 x 7 , 71 x 2 , 72 x 4 , 73 , 76 , 100 x 3 , 104 , 106 , 109 , 128 , 129, 147 x 2 , 804 , 2 Wheel Horses and Lorenzo's 2 - 804's |
Well, I'd like to say that I can help, but I can't really do that. I'm almost positive that nothing should go tumbeling out. I'm assuming that you'd have to remove the rear cover, to get to the diff, to remove the E ring. Then the axle will just slide out. Then just remove the seal, and put a new one.
Now, Purly because I dont' know what a 580 is, I'm kinda new to cubs. But I just pulled a axle tube on my 1772, but that has a hydrostatic transmission. So honestly, I'm not sure if your 580 will have the same pieces as my diff, just instead of the hydro, you'd have the gears. I['m not sure, so don't take my word. I'd listen to the experts before. :P but afaik, you'd be fine Because think about it, it's just a bunch of gears, and shouldn't they all the secured. I think you'd be fine Thanks and WELCOME You cubadict Cody |
I am not familiar with the 580. Is it like the 582 special, with a belt drive peerless transmission ?
You can look here. Just type in CUB CADET, then the 580, and it will bring up all the diagrams for you're tractor. http://www.partstree.com/parts/?gcli...FY915QodwUp7lA JOE
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
I believe that a 580 is a CCC cub that was produced during the same time that the 680 was built. I think the 580 was a stripped version of the 680 that had manual instead of hydro
Scott Larson Climax,MN Its not cold. its gods way of keeping the rif-raf out. |
Now see, that's exactly comes up under the Cub Cadet web site, parts look up.
But then there's another one. That I think is his http://www.cubcadet.com/webapp/wcs/s...1_1100505_Y_-1 If you go there Then you'll see the Quote:
it'll open a new window. and then click the first one. the 2nd is the one that he posted. I do believe that the 1st is your tractor though Just scroll down on the page that willl pop up, and click the appropriate category From the books i've got. It seems to be a 16 hp B&S 4 speed w/ mechanical lift Don't know if that's right though Thanks Cody |
Remove the wheel hubs and replace the seal without removing the axle.
Or- You could get your hands on a standard IH tranny and get rid of that POS peerless you have on there now. Scott |
OK, I found a diagram at Partstree. Doesn't look too difficult. Thanks for the help and the warm welcome.
| Thread Tools | |
| Display Modes | |
