i had this plow laying around it was from a simpl. 42" wide no frame work or anything else. I was going to build and attach the plow to an old mule drive because I have a few xtra , but I decided to just use the mule drive from the 36" blower, conect it to the tractor pull the pin the holds the blower to it and put the plow attachment thats fabed to fit the mule drive, just put the pin in and add a lift rod.I made it a bit too long tho, it sticks out from the tractor about 30" I may cut it down to about half that, but then again it proly wont matter anyws, just storeing it, but its easy enough to pull it off. 1 pin and the liftrod. wheelweights i cut out of 1" plate 10dia with 4 holes for mounting ! I made them so they sit on the lip , so they dont actually sit down on the wheel studs, it also makes it so I can put carriage bolts in from the back as there supposed to, on the other side put a nut on and it will hold all 4 in place while I put each plate on and this will help keeping them spaced from the rim a bit also. They are 25 lbs a piece
To much to list! |
Great job on your blade!
Nice work bigdaddyjak
| Thread Tools | |
| Display Modes | |
