#21
thats an excellent point, just because a part is new doesnt mean its functioning properly. ive gotten to the point where anytime i replace a thermostat i always check it with a heat gun to make sure its opening before i install it, i had 3 bad ones in a row from a reputable brand.
#22
I checked the coil according to Roland's diagram and it is only 1.5 ohms between the + and - terminals instead of the 4 - 8 ohms and only 2000 ohms between +terminal and center terminal . I'll get that changed on Monday and get a new condenser also.
Gene 149 w/Front Blade
#23
You got the fuel economical Kohler. Only runs on idle and doesn't burn much fuel.
Hope you figger er out.
#24
Glad to tell you all we are up and going. New coil, points, condenser, plug, and static timing plus the carb cleaning and new fuel filter and it is running great. The old points look okay, but just change them out along with the conderser. As a bonus, my old problem of running at 3000 rpm at half throttle is gone. I can throttle up nice and smooth without a problem. I have it set at 1300 rpm at idle and 2700 rpm at full throttle. This is a great site and I thank you all again for your suggestions.
Now to get the front blade and rear weight on before the "four letter word" gets here.
#25
Pretty sure full RPM should be around 3600 RPM's
#26
I know I'm low at the high end, but it runs fine for what I do and I figure it is a littler easier on the old engine.
#27
Im sure its already been brought up i didnt read the whole thread. I had a 102 do yhis same exact thing after cleaning and tuning the heck out of the carb i ended up finding out the condensor was bad
No more cubs. But never fear there will be more ![]() ![]() ![]()
#28
Not if you load it at all. You should set the engine to run 3600. If you don't want to run it that fast, don't push the throttle all the way up. Better to have it if needed than to lug it because you can't run it where it's designed to run.
| Thread Tools | |
| Display Modes | |
