Old 11-26-2015, 04:13 PM
gdheck's Avatar
gdheck gdheck is offline
Default Will a 335 bagger fit a 54" deck?
I know where there is a 335 bagger from an 1862 with a 46" deck. Will this fit the 54" deck on my 1864? I can't seem to find anything but the fan assisted bagger listed for the 1864.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 11-26-2015, 05:21 PM
The discharge opening on the 54" deck is much larger than the 46" deck so the boot wouldn't work.
I don't know if the 54" deck has enough poop to kick the clippings up into the bagger. The 46" works well for that.
Old 11-26-2015, 07:22 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
It doesnt, you need the blower for the 54 and 48" deck
1- 1200 in pieces
1- 1864 in pieces
Old 11-28-2015, 06:55 AM
bugeye bugeye is offline
What Mike and Rescue said is correct. I have a 54" deck on my 1864. I also have a discharge chute purchased with my Trac Vac that has a 6" round discharge. Using a MTD grass collection system, the grass never quite made it into the bags without clogging in the tube to the bags. I tried a custom mower blade with larger turned up ends, but no real improvement in clogging. I abandoned the bagging system.
Old 11-28-2015, 11:21 AM
gdheck's Avatar
Is the 46" deck what they called a high vacuum deck and would it blow the grass into the bagger very much better? Maybe I should see if it is for sale too. I would rather find a Trac-Vac, but you almost never see them for sale around here. When you do find them, they are too expensive for just once or twice a year use.
Old 11-28-2015, 01:23 PM
The 46" is the high vac deck and it does a good job of blowing leaves and grass clippings in the bags. I used a bagger one for awhile on a 46" deck. They leave the lawn clean but the bags fill so quick with leaves you spend a lot of time dumping them.
I have used a 46" high vac deck with a EZ VAC like the picture for over twenty years. It is a great combo. Leaves nothing on the yard. I have a lot of leaves and it's the best money I every spent on anything.
I had 5-6 tractors with the 46" deck and thought they were great. They were until I tried the later 48"54" decks and they do a much better job of leaving a good looking cut on the lawn so I changed them all over to the 48/54 decks except for the one dedicated tractor to leaf duty.
