Old 12-24-2015, 07:54 PM
rocker582special's Avatar
rocker582special rocker582special is offline
Default Is it hard to mount a 3pt hitch off a Sears garden tractor on a Cub Cadet?
Hi guys. I recently got a Sears 10xl in a trade I made. Well I'm wanting to sell the tractor but I really wanna keep the 3point hitch off the back of it for one of my Cubs. My question is how hard will it be to mount on a cub cadet? Thanks for information in advance and Merry Christmas.
Old 12-24-2015, 08:00 PM
If you have a welder and a torch you can do it.
Old 12-24-2015, 09:52 PM
Thanks olds for your help.
Old 12-24-2015, 09:57 PM
I can't find the picture but it takes an adapter plate and you need to modify the handle to clear the cub cadet fender.
Old 12-24-2015, 11:57 PM
thats what im here for.
Old 12-25-2015, 06:42 PM
Is this adaptor plate hard to find Jeff?
Old 12-25-2015, 08:23 PM
I'm sure it was home made. If I remember correctly, it was mounted at the top where the Cub Cadet rear lift casting pivots and bolted onto the lower rear sleeve hitch adapter U shaped bracket.
What model CC are you going to put it on?
Old 12-25-2015, 09:57 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Dad built a really nice adapter bracket years ago that works like a charm... Then you just bend the arm to clear the cub cadet fenders.. The setup works like a charm.. We really like the Sears hitch and equipment a lot better than the brinly stuff.. Adjustments and fine tuning are easier.
I will try to get you some pictures in the next day or so. We currently have the setup on a 128.. Dad probably built 10 or so setups over the last 20 years.
Basically it converts the flat rear cover area on the cub to the angled mounting area on the sears.
Jay
Proud owner of the following:
Old 12-26-2015, 02:50 PM
Not totally sure. Either my 582special or my 70. Not sure which would be easier to mount it to.
Old 12-26-2015, 02:52 PM
Jay, I looked at the back of the Sears and it looks like only 4 bolts holding it on the back.
