#21
I understand about the tin plate. But I'm referring to the draft plate that goes on the sleeve hitch before you attach an implement. It keeps the implement from drifting side to side when you tighten up the bolts. Any pros and cons on that?
#22
Here you go. You're missing some of the pieces like the lower bracket and sleeve hitch adapter. Jeff and others make them
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
#23
Actually, I have everything I need. Sleeve hitch adapter, lift assembly, etc. But there is a draft plate that I've seen. I was wondering what everyone's opinion was on using it.
#24
If you're talking about the bent disk with the hole in it... I don't even own one. All but one of my implements are wide enough where they attach to the sleeve hitch adapter that the jam bolts work just fine without it. Right, wrong or otherwise, depending on the implement and what I'm doing with it, I don't snug up the bolts either.
#25
Thanks Sam. It didn't seem to have any purpose. And I was also wondering if the jam bolts were supposed to be tight. I would think the implement should have some play so you don't bend and break things.
#26
So when installing the lower hitch link, will I lose any rear end oil when I remove the bolts? Can I reinstall the fixed draw bar over the lower hitch link? If so, how long do the new bolts have to be?
| Thread Tools | |
| Display Modes | |
