Old 03-24-2016, 09:02 AM
samckitt samckitt is offline
Default 1782 slows going up hill, normal?
So forgive me if stupid question, never had a hydro drive tractor on hilly property before. But when going up hill, forward speed slows down, without noticing a change in engine speed, its not bogged down. Is this normal?
Thanks
Old 03-24-2016, 09:11 AM
CubDieselFan's Avatar
How much does it slow down?
Old 03-24-2016, 09:12 AM
Thanks
Yes !!------- it does not have a "cruise control"
Old 03-24-2016, 09:13 AM
Ditto............
Old 03-24-2016, 09:14 AM
cubs-n-bxrs's Avatar
Does it speed up going down hill as well? Sounds to me like it's time to overhaul the trunnion.
Old 03-24-2016, 01:29 PM
Enough that I think "why is it going so slow". ????
Old 03-24-2016, 01:32 PM
I get that, but has a lever that controls speed, & it isn't moving & engine isn't bogging down like it would with gear driven. Not 100% sure how this hydro setup works, does the fluid pass through gears to give the forward movement? Is there enough gap between gears & housing that it is bypassing the gears?
Haven't noticed that like I do going up hill.
Old 03-24-2016, 02:21 PM
No gear pump, it uses pistons in pump/motor
Here is a good understanding of how it works:
Read it through
http://inspectapedia.com/heat/Sunstr...msn_Manual.pdf
Old 03-24-2016, 08:17 PM
Slows down quite a bit up hill, and does speed up going down hill.
