Old 09-28-2016, 09:56 PM
Tim.E's Avatar
Tim.E Tim.E is offline
Default Golf cart front hubs on a Cub Cadet?
Has anyone measured golf cart front hubs to see if they might be adapted to use on the Cub Cadet front spindles?
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 09-28-2016, 10:42 PM
For what purpose?
Same size spindle, so no added weight bearing ability.
So you have to unbolt 4 nuts instead of 1? That sounds like more work.....
Yes, there are hubs out there that go right on the front spindle to give you a bolt on rim.
Old 09-29-2016, 05:56 AM
twoton twoton is offline
Originally Posted by Tim.E View Post
Has anyone measured golf cart front hubs...
Sorry Tim.E I have not. This is the only information that I could come up with on spindle upgrades, hope it helps. And If you would like my opinion on the subject feel free to ask. Good luck with your project and have fun!
https://www.youtube.com/watch?v=_pGIvyQG700&t=295s
Parts from Xtreem;
http://www.xtrememotorworks.com/Part...ont%20Hubs.htm
More reading on spindle upgrades;
http://www.onlycubcadets.net/forum/s...709#post370709
What I did;
http://www.onlycubcadets.net/forum/s...613#post330613
You can also get parts from Surplus Center;
http://www.surpluscenter.com/Wheels/...es-Wheel-Hubs/
Good luck and have fun!
Old 09-29-2016, 09:35 AM
So... I want to hear your opinion.
You answer a lot of questions on here, by referencing your one build on of the two Cub Cadets you own. (Two is all that I could find you have posted about, you may own more.) You own and run a lot of equipment, so I trust your judgement on uses. You did upgrade your spindles... most all of us remember the extensive you work you did to that one Cub.
You run a QA42 snow thrower on it I believe, which is quite a bit lighter than a 450 style snow blower. In the roughly 200 hours or so I've ran my 450 on an 1811, I never wore out or broke a spindle. So, I think it's safe to say that the blower isn't too much for the standard set up. I don't see that you own a loader or add any other weight otherwise not added to any other stock front end Cub.
So, here's the question.... how did the spindle upgrade benefit you? If you say yes, be careful, as your axle probably was in need of a rebuild anyway.
Tim E:
You have done some really cool custom builds. If your going for a particular look, or a different tire set up, then I understand what you are doing and by all means go for it. What I'm saying is, unless your going for something particular, there is no benefit to the cost unless you also upgrade the spindle by doing something like twoton did, or TIM CRUTCHER. Check out his SGT build with the larger front tires here:
http://www.onlycubcadets.net/forum/s...ad.php?t=30384
Old 09-29-2016, 10:01 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
or maybe better to just
Old 09-29-2016, 06:39 PM
Hey Jon, thanks for the kind words. Not trying to be a smart a$$ but it should be noted that I was addressing Tim.E. Feel free to send me a PM and I’ll be happy to share some of my opinions.
Old 09-29-2016, 08:15 PM
Tim.E's Avatar
Thanks,Gentlemen for the input.
I just like the 4 or 5 bolt hubs because they "Look Cool''.
Also it allows me to use narrow rims on the 1" Spindles on the "Super Steer" axle.
Here is how I did one.Actually,my Buddy,Jesse Reed Made up the hubs for me.I used OEM Cub Cadet 1"ID x 2"OD front wheel bearings.
Of Course Aaron at EXTREME Motor Works makes some SUPER NICE front front hubs also.
Old 09-29-2016, 08:26 PM
Tim.E's Avatar
Plus,I am using these on my next build.
(Whenever I get a Shop.I sold my old place and am looking for a new place,and the house I am renting does not have a shop)
Old 09-29-2016, 09:03 PM
john hall's Avatar
I do like the look of the 4 bolt hubs and rims on those customs. So you gonna spill what the next build is going to be or do we have to wait until you start it?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-29-2016, 09:28 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Very nice!! I like the look of hubs also...
Nice custom rig!!
Jay
Proud owner of the following:
