Old 01-24-2017, 09:21 AM
drcjv's Avatar
drcjv drcjv is offline
Default Advice needed
I am rehabbing a cat 0 brinly plow. The surface of the plow bottom is rusted and pitted what is the best way to prepare the surface for use. I concidered a grinder, sanding disc but I do not want to make it worse. I am sure if i used it it would polish up but I do not have any where to plow.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 01-24-2017, 10:34 AM
I sandblasted my plow and painted the white parts with good paint, the rest of it I used aerosol epoxy and aerosol black krylon. When I took it to the first plow day the paint wore off and it shined like chrome in about 15 minutes, after I was done plowing I put a bag over the white and sprayed some black on the plow to keep it from rusting.
Old 01-24-2017, 10:56 AM
drcjv's Avatar
Tim I know if I use it it will polish up. I am not going to use it. I want to sell it. I guess I could paint it but I was hoping to get it all shined up.
2072 50" deck
Old 01-24-2017, 12:30 PM
cub123's Avatar
cub123 cub123 is offline
When I did mine I cleaned it real good with a wire wheel, polished it up with a little sandpaper, and just put some olive oil on it. It sat for a few years in the barn without rusting, until the stupid cat peed on it
Old 01-24-2017, 04:33 PM
Got any dirt roads nearby? My brother shined up his little genius #8 plow pretty good by setting it almost down to the stones and rode up and down it a few times. Apart from that just plowing....
Old 01-24-2017, 04:44 PM
Merk Merk is offline
I sold several plows last year. I used a sanding flap disc to remove the rust. Them I gave a coat of Pam cooking spray and wipe the extra off.
Project Uncle Dick
Cub Cadet 70
Sounds like a moving target for you to practice on.
Old 01-24-2017, 06:13 PM
cub123's Avatar
That cat has almost "disappeared" a few times.
Old 01-24-2017, 07:02 PM
LMAO, I've seen a couple go away, I wonder what happened? Way back when I lived in CT my late wife had a nasty cat, well it made the mistake of clawing me on the way out the door to go to work. I grabbed it, stuffed it in a garbage can and dropped it off at the quarry. Bye Bye Kitty.
Old 02-03-2017, 07:08 AM
drcjv's Avatar
Who is hording all the cat 0 plows I used to buy 3-4 a year now you can't find one for sale. Non on craigslist and one incomplete on ebay. Some body out there must be sitting on pile of them.
2072 50" deck
