Old 06-05-2017, 04:16 PM
Originally Posted by mjsoldcub View Post
epoxy primer is a 2 part primer...it has to have a catalyst to get hard, like epoxy....it has superior bonding capabilities which allow it to seal metal exceptionally well...and it is STRONG,and very chip resisitant... sometimes called 2k primer...
No, 2K primer is different from epoxy primer.
Old 06-05-2017, 04:23 PM
Epoxy primer is designed to etch into the metal so it gets a good bite, some 2k primer is approved to go over bare metal and will usually be marked DTM for direct to metal.
Old 06-07-2017, 12:36 PM
yeah i shouldve been more clear in what i meant...epoxy primer and most 2k or 2 part primers ive ever used required a hardener or catalyst... there is a difference in the base resins, Jon is right, i dont remember what is what, and Tim knows what hes doing....epoxy will be the best sealer rust inhibitor, and the 2k will fill small voids etc....
just used to calling a 2 part a 2k... i even used an epoxy primer from germany that came in an aerosol can along time ago..had to punch a button on the bottom and shake for said minutes and no good after like 12hrs or something like that....
anyways good luck with it
