#181
I got these tool boxes from extrememotorworks. They solved my problem of how to carry essentials and made the space under the seat useful.
A 122 with weights and a deck for mowing trails. 100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart and snow plowing. 100 with weights for wood hauling. Rusty functional 102 with rear lift. Elec Trac E15 for finish mowing. |
#182
thats a cool addition!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
#183
Nice boxes! I'd venture to guess there are holes for water to drain out?
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#184
The boxes are just folded metal, so they are not really water tight. They replace the fender mounting brackets. I can't leave the 100 out in the rain because the foam in the seat would get waterlogged.
#185
Got my herd out in the sun today, changed oil on my 1450
Just rebuilt the engine
So as the IH Cub Cadet projects reside, and pick up, a while ago I had removed the battery, drained the fuel from the tank and carb, and cleaned up the sediment bowl to tuck away my 125 under a cover for storage. Won't be until spring when it comes out next, lol! I might enter this 125 in the local ( Ohio's oldest ) fair next year for being nearly 100% original, and in exceptional condition!
![]() got a new key chain for it this year. ![]() and one for the taking,.... ![]() I'll have to dig out the mower, and put it on come fair time.
#187
Nice herd Garyoh5a! Which one is your favorite and why?
INTERNATIONAL HARVESTER - We build the machines that work. 1811/682/782/1440/IH #4/IH QA 42" |
#188
Hi guys I remounted my engine today, I say remounted because I mounted it before and the bolts shook themselves loose. The rear bolts were easy but god, the fronts are impossible without a jack. Last night I got a 104 and 2 engines plus tons of parts for 50 bucks. Im wondering what to do with it, im open to suggestions.
#189
new used rims purchased locally to replace the rusted ones that had calcium chloride in them.
I made the mistake of not removing both at the same time so I had a seesaw for a minute. Didn't think that one thru. Now I need to get the tires broke loose and see if the rims are salvageable at all. The tires are still decent. Those tires are welded onto the rims too yowzas, Might be heading to a tire shop to break them down. New air filter installed. Tractor moves pretty quick now too with 200 lbs~ removed.
Cub Cadet 129 |
#190
I was getting the tractors ready for plow day tomorrow and noticed some bits of blue shop rags coming out of the grille, this is what I found. I got everything cleaned up with the shop vac and it's good to go.
| Thread Tools | |
| Display Modes | |
