Old 11-20-2017, 05:24 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default 782D stopped hydro-ing...
Long time no see, friends!
I was doing the last clean up of leaves (maybe) this year and was bringing my 782D back towards the garage. I was motoring forward and lifting the deck at the same time and hydro pressure just died.
There's no propulsion or any lift of the deck. Engine runs fine, and there's no leaks.
Where to look first?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-20-2017, 05:54 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Check the spiral pins on the drive shaft.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 11-20-2017, 06:01 PM
I agree..
Better lay on some spares while you are at it, you are gonna need 'em
Old 11-20-2017, 07:28 PM
http://www.onlycubcadets.net/forum/s...ad.php?t=50335
Old 11-20-2017, 10:39 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
http://www.onlycubcadets.net/forum/s...ht=pins&page=2
Dowel pin on engine end.
Spirol pin on pump end.
Check pin holes for elongation in all parts the pins touch.
Eliminate elongations.
Jeff in PA makes a dowel pin that is slightly bigger to fit into shaft at engine end when pins are being slung out.
Old 11-20-2017, 10:55 PM
The 782 doesn't run a dowel pin at the front of the shaft like the older Cub's.
Old 11-21-2017, 06:12 AM
John, you sheared the pin off at the hydro input shaft.
http://www.onlycubcadets.net/forum/s...hlight=sheared
Old 11-21-2017, 11:47 AM
jbrewer's Avatar
Sounds right but wasn't right. All pins are working, input to hydro pump is spinning. I will double check this though.
I did discover that the DPO neglected to tell me that all the fins on the cooling fan were broken off.
Any next hints?
I can see that the linkage from F/R lever is working fine.
BTW, this stopped all of a sudden...there was no loss or degradation before the failure.
John
Sounds right! I'll have to go see how to tunnel cover removes and give a look see. Doesn't sound too bad.
I guess the load of pumping the PTO lift and the motor at the same time exceeded the (probably OEM) shear pin.
Back in a bit!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-21-2017, 12:42 PM
jbrewer's Avatar
To no ones surprise it does indeed look like the spirol pin! I drove it out and it came in small pieces.
Thank God for Kroil and long roll pin punches!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-21-2017, 01:18 PM
Was it a spirol pin or a plain roll pin?
