Old 10-10-2010, 12:36 AM
123maxbars 123maxbars is offline
Default Engine Trouble cub 122
Here is my issue with my 122, it has a new rebuilt motor straight from machine shop, runs strong, no starting issues,smoke etc, idles very well. However this is the problem I have. When I switch out of 1st gear to 2nd or 3rd, I sometimes loose power and the motor dies. And it sometimes keeps power but the RPM's go down and so does the throttle even when I keep it the same as I did in first gear. However, if I keep the tractor in 1st gear it runs with the best of them. also when in N such as coasting downhill it will loose power, any suggestions will be helpful. Thanks,
Old 10-10-2010, 08:22 AM
Two things come to my mind. Check the Carburetor and Governor settings and adjust as per the engine service manual.
Old 10-10-2010, 10:04 AM
cubs-n-bxrs's Avatar
Definitely check the Governor setting. Simple procedure.
