Got it figured guys.
darkminion_17 drew my attention to using aftermarket parts. Pulled the engine off and clutch assembly out. Mic'ed the aftermarket plates with my original plates....after market plates MUCH thicker, took up the free play area. I was trying to beef things up a bit...am installing a K341 on the 73. Its a workhorse around here. Had already resurfaced the original plates, so just used those. Everything A-OK now. Thanks again guys. |
Hello, if those are Zack Kerbers, i know his pulling plates are thicker and use different hole locations for the driveshaft. I don't know if he has stock plates. Mike
mickb72 you are correct those are Zack Kerbers.
I didn't know they were that much thicker. I see he has drive shafts as well, however trying to find a machine shop around here to drill the hole for input shaft is like pulling teeth. Thanks for all the info guys. |
Tell me the locations you want the holes and I'll make it to your specs. $30 plus shipping. Jeff |
If your plates are too FAT and you aint got no machine chop available I bet Jeff would skinny em up for ya to if you asked??
I can thin your plates too. Your choice on either option
I think that clutch was a bit overkill for the application..... but whatever.
I wouldn't turn the disk down, as you spent the money on a heavier set up....why kill it? I would suggest getting the proper shaft made. |
New driveshaft?
Who drilled the holes. Are you using a Cub Cadet throw out bearing or an aftermarket throw out bearing? It sounds like the holes in the drive shaft are in the right location. I've used the thicker clutch plates and didn't have any problems. You should have enough adjustment using thicker plates. Quote:
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
![]() Me thinks that you may have ordered the wrong driveshaft there gscott. Zach has two versions, narrow hole and wide hole... |
I just stated what I use.......no need for overkill.
| Thread Tools | |
| Display Modes | |
