#51
Thank you Sam and Travis°•○●□■♤♡◇♧☆▪¤《》¡¿
#52
Looking good Sam. If I ever get into my 1782 I might give you a call.
Btw I thought the purpose of the fuel solenoid was to prevent backfiring on engine shutdown? I know that they all get circumsized but does anyone ever have a loud flame thrower after surgery? I know that most of us let them idle for a while before shutdown but I’m just curious.
#53
If you have one that wants to diesel after you turn the key off just pull the choke.
#54
What is the purpose of the screw?
I have one on a CH 18 and I am curious, does it work like the throttle stop on the k series engines ?
#55
Lew it prevents the throttle from going full open.
#56
Does that mean the engine runs higher rpm then a stock18?
#57
Yeah Sam, is it going to blow up my engine?
#58
Same RPM.. the screw just limits the opening of the throttle blade on the 18 to about 75%.. kinda like a restrictor plate.. so it was just a cheap way for Kohler to build the same engine and rate them as two different engines.. Governor must also be reset to gain full use of the extra 2 hp
Won't blow it up Lew.. just allows more air and fuel in at the time.. Won't allow any more RPM.
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
#59
Got a few things done on #2 seal has been replaced, engine is back in, CV joints are cleaned and repacked, new fuel lines, tank bushings, fuel shut off valves are cleaned, tank is back in place. Now onto wiring.
#60
I hope to be done with this one this week. Wiring is almost finished. Just need to redo the battery cables, hook up the fuse for the PTO and connect it to the battery then I need to put the split loom on the wire harness. Everything works as it should. Low oil press light and low fuel light work, PTO turns on and off, it's charging as it should, headlights work as you can see in the pics.
| Thread Tools | |
| Display Modes | |
