Old 06-29-2018, 01:29 AM
Redblower's Avatar
Redblower Redblower is offline
Default Disc, general farming questions
I have gleaned some info from searches but I know there are life long experts here that can answer these questions.
I have a 3 point (homemade) with down force option only, so far as I know.
I just wanted to have some implements to play with so found a good deal on a Sears single gang disk in excellent condition, built a sleeve hitch adapter for it to hook to my 3 point.
After a couple of attempts I am going to assume that a disc needs to float?
Is this correct? (wish I would have paid more attention 40 yrs ago on my uncles farm).
As always any wisdom is greatly appreciated, and yes I know I probably need a 8" moldboard to hit it with first but this was the first I found.
Running a wf, 782 for the record.
Thanks,
Vic
Old 06-29-2018, 02:40 AM
All 3pt tillage equipment needs to float. You can't force it into the ground or you lose traction. You need to slot the lift straps if you haven't already.
I have a Brinly disk. They are almost piss-ass worthless. Even on plowed ground, the disc blades have too deep a dish, and can't be angled enough to make it work. I kept it, but I have some ideas for it I just haven't gotten to yet.
Yeah, you need to find a plow. The disc will not break ground. It will kind of stir the dirt if you plow first.
Old 06-29-2018, 03:37 AM
Steve N Mi Steve N Mi is offline
Yes the disc needs to float but that doesn't mean you can't load it with lots of weight to make it work.
btw, is that an 8 or 10 blade disc?
Old 07-02-2018, 09:17 PM
Redblower's Avatar
Odd angle pic, po had rigged up the tow behind for his quad, pic of tag also.
As you can see it's a 10 blade, they are 11.5" in dia.
It's all a learning experience for me, wanted something to play with, and was able to build a good sleeve hitch adapter that will hopefully come in handy later, as I'll be looking for a plow, maybe I can find another one and mount them together.
I was wondering if slotting the lift straps would work, it seemed right but happy to have someone verify.
thanks guys, any other info is greatly appreciated.
Vic
Old 07-02-2018, 09:20 PM
Or you start breaking things................
