Well I took everyones advice and got the rear axle reinforcements for the 2072. No instructions came with them but its pretty straight forward so I just took the weight off the rear end and bolted everything up. Refilled fluid and now I have a leak at the axle tubes. I installed the thin washers on the outside of the braces, should they be between the brace and the tube? Or am i forgetting/missing something else?
If I'm taking it apart again I want to do it right this time because refilling is annoying and time consuming. |
I think you need thread sealant on the bolts so it wont weep out.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
I just installed a set on a 1772, I put the washer under the head of the bolt and used little silicone sealant on the threads. No problems.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Thanks guys I’ll pull them out and put some sealant on them, maybe I’ll work faster this time around lol
You can use a vacuum cleaner hooked up to the dipstick tube when you pull the bolts out. The suction will keep the oil from running out of the bolt holes. I use Permatex # 3 on the bolt threads. Clean the threads first with some brake clean.
I like that idea! I’ll let you know how it goes. Thanks
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Yep, I use an old vacuum pump for HVAC work to suspend the oil in the rear when replacing a leaking bolt. I use Permatex #2 and torque to 30 ft/lbs. Just make sure the area is clean so you don't suck any junk into the hole.
Will these braces interfere with the SGT cat 0 hitch? Looks like part of the brace mounts where the lower lift arms mount.
Adrian 2072 (789513) |
I have Diesel Doctors 1772 and it has a 3 point. I will look at it closer and shoot some pictures.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
| Thread Tools | |
| Display Modes | |
