Old 09-29-2018, 12:30 PM
IHCubCadet147's Avatar
Default Float Button
On a 126, what holds the float button in? Should it be glued or something? I just put one on from an extra lift arm I had, and it doesn't fit tight, it keeps falling out.
Old 09-29-2018, 12:43 PM
dale c. dale c. is offline
they're a pressed fit usually 1 time use only because they collapse a little bit when pressed in ..you could try a little Loctite not sure it will work foy you or not ...
Old 09-29-2018, 01:33 PM
I didn't know that. I'll try loctite. Thanks!
