Was the hydro disconnect a real thing? I've seen mentions of it but never actually seen it.
Edit: Huh... apparently it is. I don't see how you would use the hydrolift with the brake pressed, though.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210 Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60 |
Yes it was made up...
On the 1650 it is basically, like wow, putting a clutch from a 1000 on a it.
Mainly it was to make cold starting easier.
That is pretty cool. From the description, it seems as if this is a centrifugal clutch. In my view, I'm seeing something similar to the clutches we see on minibikes. Did I get that right?
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
I don't own one, but from the description, it sounds like you are right.
Best thing to do is remove that unbalanced pos and leave it in the shop. I pull every one of those off of my diesels.....but then again I'm not trying to start a tractor when it's 20 below 0 either.
Those are for the MTD tractors, IH also had it for at least the Quietlines maybe others. It was just a gear drive clutch installed on a hydro tractor.
| Thread Tools | |
| Display Modes | |
