Old 01-02-2019, 12:03 PM
gtpicker01's Avatar
gtpicker01 gtpicker01 is offline
Default Cub 104 clutch teaser spring issue
I'm looking at a 104 to possibly purchase for a plow tractor, but the one I'm looking at, the owner says it breaks a clutch teaser spring every year. He still uses it weekly to mow grass, but what would cause it to break a teaser spring every year? Think it could be assembled wrong?
Proud Owner of These Fine Cubs
1961 Cub Cadet Original - 1966 Cub Cadet 102 - 1967 Cub Cadet 104 w/ hydraulic lift
Old 01-02-2019, 01:25 PM
athomas's Avatar
athomas athomas is offline
Assembled wrong,worn driveshaft,misalignment issue, I haven't done one lately but if assembled correctly with the right parts it should not break !
Old 01-02-2019, 01:54 PM
gtpicker01's Avatar
That's sort if what I thought, I've never put one in, but I believe i saw in another thread that the way it is shown in the parts diagram is wrong?
Old 01-02-2019, 05:44 PM
Merk Merk is offline
Is this throw out bearing a Cub Cadet version or a cheap aftermarket version?
The after market throw out bearing is thicker than the Cub Cadet version.
Project Uncle Dick
Cub Cadet 70
Old 01-02-2019, 07:23 PM
athomas's Avatar
I recall the same thing about the parts diagram being wrong and somewhere ( likely here ) seen the corrected version, I may have it copied or noted it somewhere and I'll try to look for it tomorrow and send it if/when I find it !
I think my 108 had a hatefully worn/grooved/taper on it where the throw-out bearing slides and after replacing the driveshaft things aligned better and clutch worked much smoother without breaking the teaser spring !
Old 01-02-2019, 10:38 PM
gtpicker01's Avatar
Not sure, but if I can make a deal on this machine we will find out.
I've never worked on a cub cadet clutch before so this could be a learning experience!!
Old 01-03-2019, 08:56 AM
by gtpicker01
Yesterday 07:23 PM
Here is a how to rebuild a clutch that I did.
https://www.onlycubcadets.net/forum/...l+transmission
Project Uncle Dick
Cub Cadet 70
Old 01-03-2019, 10:13 AM
gtpicker01's Avatar
Thanks! That will help a lot! Those diagrams at the end are super helpful!
