I've got precision calipers, just not the correct indicator tools for the bore. The crank was fine and the specs with within normal limits for a non-ground journal. When i was taking the balance gears out (was forced to) i noticed what had to have been too much end play in the cam, haven't read up on that too much but i am nearly certain that's where the more serious sound noise was/is coming from. The smoke you saw was from about 100 little holes in the muffler shooting smoking oil back onto the block. The tapping is defintely a mechanical noise in the valve train. See the below video i took earlier this evening. (edit: i need to point out that after compressing the video to upload that it makes the valves look completely off timed and all over the place, that's just a visual effect of not even enough frames per second) VIDEO:
You cannot use calipers to measure a piston or bore, or anything in the engine, for that matter...you need a micrometer.
I just wanted to make sure...I wouldn't want to see you or anybody else get led astray by using the wrong tools to measure something and then consequently making the wrong decision.
First of all let me say I know nothing about the Kohler one lung engine.
That is to say I have never had one apart. I have to agree with Merk though. A blown head gasket will sound like rod knock. I do not see that much smoke from the muffler. It looks like the smoke is comming from the side. Did you install a pan gasket when you put it back together? |
All gaskets were present. If you look at the video i posted in my last reply, you'll see the motor turning over with the head off and still making lots of noises, both from the top and low end. |
| Thread Tools | |
| Display Modes | |
