Thanks for all of the advice guys. I picked up a25 757 01-s rebuild kit, and sure enough the square ring gasket was the same size. However, to my amazement, the original ring had shrunk substantially since I last tried to install it. I was now able to easily install it.
I had soaked the ring in fuel and left it that way before originally trying to install it. Not intentionally - just ended up sitting in fuel while I got distracted and worked on something else. I think the ring swelled while sitting in the fuel. These kits say not for use with ethanol fuel. Well, we only have ethanol fuel available. I think it reacted with the fuel and swelled. I work with hydraulics and have seen this happen before. Usually with solvents though. If it gives me trouble moving forward, I think I'll source a square ring made out of a different material.
Current Fleet: 100, 126, 147, 128, 1450, 1650
Usually the rings don't give a problem when installed, as they are captivated in the groove.
Watch that the needle stays seated. Many times it only takes a hair to cause a seepage when setting unused. but after some usage usually any "stuff" that gets in the line, works itself through without further problems The neoprene will tolerate the regular 10% alky, it it the higher percentage blends they speak of, that causes problems. |
| Thread Tools | |
| Display Modes | |
