I have a 147 with a broken rod. Noticed the long dipstick is broken or cut off. Dont know why or how. I see another shorter stick on the motor. Can you use the short stick to measure the correct oil level? Why 2 sticks???
The 147 rolled out of the Factory with a Kohler K321S‐60226D engine in it.
That K321S had only one dipstick and that is 237620-S. Anything other than that, is a PO modification or hack job.
![]() Quote:
https://www.onlycubcadets.net/forum/...1&d=1627480878 |
Looks like you got an older motor (long dipstick) with a PO modified/installed cam cover dipstick.
The old K block used longer dipstick until Kohler began adding balance gears. That made it necessary to move the dipstick somewhere else... .which is on the cam gear cover by the points.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
![]() Quote:
![]() Quote:
YES motor is original. All I want to know is if the short stick is accurate to measure the oil and how much does it hold. My long stick is. Broken.
https://www.onlycubcadets.net/forum/...1&d=1627561111 |
Can't read the tag.
Thread Tools | |
Display Modes | |
