Old 09-19-2022, 12:32 PM
Cjgruber78 Cjgruber78 is offline
Exclamation CC 1541 Starting Issues
Hi All-
I have a 1541. About a month ago I got it running. After about three minutes running it started to bog down then stopped. When I try to start it now I get three dash lights. Those are: Low Oil, Battery and Disengage PTO. When I flip the PTO switch, I hear a click like engaging, but the engine will not turn over at all. I replaced the switch, oil, filter, fuse and still nothing. I bridges the solenoid and have good spark.
I am about out of ideas and could use some advice
Thanks
Old 09-19-2022, 02:00 PM
Battery dead? Check all connections, you have to be sitting on the tractor, to start it.
Up to 530 and counting...
Old 09-20-2022, 01:49 PM
Hi There
Brand new battery. Dashboard lights up. When I sit on the tractor it does not start. I switch the PTO switch back and forth, hear a klank and engine itself doesn’t even attempt to turn over.
Old 09-20-2022, 01:58 PM
Inactive Member
In order for the Starter Solenoid to engage, to roll over the engine, (A) the PTO Switch has to be in the "off" position, and (B), the Brake Pedal has to be depressed.
Now either switch could be bad, or a wire connection to either switch.
AS A TEST......
Run a Jumper Wire from the Brake Switch wire RED/BLK to the small (RED) terminal on the Starter Solenoid. Turn the Ignition Switch to start, does the engine roll over ??
Old 09-27-2022, 02:32 PM
Question 1541 Update
So I replaced the ignition switch and now the lights work. When I now use the ignition switch, there is a clicking in the reverse relay switch. What would cause this switch to click? Engine still will not turn over.
Tags
1541
