Old 09-16-2024, 08:16 AM
ironman's Avatar
ironman ironman is online now
You need something like this, kinda pricey though....
https://www.colemanracing.com/Steeri...Drive-Gear-Box
Old 09-16-2024, 10:31 AM
Ambush Ambush is offline
I should clarify and probably add some confusion at the same time
When I said " pump rotation is from looking at the input end" I should have said for standard applications. In the case of these hydros, the shaft protruding from the "back" is actually the input for normal pumps.
So even though your "input" turns CCW (left hand) the lens plate inside is CW (right hand). If you want to change direction, you will need a CCW plate.
There are several videos online that will give you a very good idea of what is involved in a teardown and hardware inside, but each one contains a few things that are definitely not the correct procedure. But still very helpful from an understanding point of view.
Just google sundstrand U15 repair video
You could consider turning your engine and driving to the rear pump shaft. Looking AT the flywheel, it is turning CW. Placing the engine with the flywheel to the rear over the rear shaft of the hydro should give you the correct pump rotation.
It's early morning here and I'm only done half of my first coffee, so verify that.
Old 09-16-2024, 11:05 AM
KMCub KMCub is offline
The price of that doesn't scare me away and conceptually that is what I need the only problem with that specific one is it would never handle continuous power, it is just made to reverse a steering shaft.
Old 09-16-2024, 02:25 PM
I appreciate the info. I would simply rotate the engine if it would work with the sheet metal. I am using a 1250 with side panels and wanted to keep it all intact for asthetics, cool is expensive...
Old 09-18-2024, 10:08 AM
Looking forward to seeing your build progress. Keep us updated.
Always interesting to watch innovation. Good luck!
