Old 01-17-2011, 11:18 AM
nycub122 nycub122 is offline
Default Wide Frame Questions
What is the difference between the narrow frame and wide frame creeper? I understand that the handles are a differnt part #, what are the dimensions?
What is the difference between the narrow frame and wide frame 3 point hitch?
What are the advantages/disadvantages of the electric lifts vs the hydraulic lifts?
GEL
Old 01-17-2011, 12:06 PM
The handle on a WF creeper is longer, and the hole for the roll pin that holds on the shift fork is at an angle with the handle part. On a NF creeper, the handle is shorter, and that roll pin hole lines up with the handle.
The WF and NF 3-points are different. The only piece that is the same between the two is the lower bracket.
The electric lifts are weaker and have expensive and potentially hard-to-find parts. The NF hydraulic lift also has some commonly-broken parts that are difficult to find. The WF on up hydraulic lift uses the charge pump on the hydro, and is quite robust and reliable and has a higher lift capacity.
Old 01-17-2011, 12:33 PM
So, all I would have to do to use a narrow frame creeper in a wide frame is change out the handle?
GEL
Old 01-17-2011, 12:34 PM
Yes, or bend and extend the existing handle.
