Old 03-20-2011, 05:47 PM
litlmikeyl's Avatar
litlmikeyl litlmikeyl is offline
Default NF Hyd. Cylinder Disassembly & Interchange
What is the proper way to disassemble the lift cylinder for the add-on hyd. lift unit on a NF Cub? Is there a cylinder from a different application that would match up fairly close to the NF lift cylinder, in case mine is beyond repair?
Thanks everyone
Mike - Ramsey, MN
'65 100 - #126432
Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter
Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower
Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles
"Why buy something shiny & new when you can save something old."
Old 03-21-2011, 09:25 PM
mmzullo mmzullo is offline
If I remenber correctly. Remove the 2 hoses put the piston in a vise at the front mount hole and put air in the rear hole. Be careful the piston and rod should come out if the outer tube is not bent. There are only orings as seals. I did one about 7 years ago and I think thats how I did it. It's not hard. The rear hose mounts in the outer plug.
